-   -   Retighten Permimiter Bolts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/500820-retighten-permimiter-bolts.html)
Mark McClure 09-22-2009 06:32 PM
Hi,
I have a issue with a leaking rear main seal not from the crank but from the outer bottom edge where the case joins. I am about to take the engine out to fix this again (second time) and wondered if I should tighten the perimeter bolts around the seal.
The concern is that the sealant has hardened and that changing the torque of the bolts will effect the sealing properties, in a bad way.
Any thoughts?
Mark....
Flat6pac 09-22-2009 07:18 PM
Well, youre already leaking so you cant do much more damage and if you dont try it you ll never know
Bruce
Mark McClure 09-22-2009 07:25 PM
Good point....but it could leak more....!
mca 09-23-2009 01:13 PM
I am inclined to believe the same thing.
How bad is the leak? Are you sure of the source?
304065 09-23-2009 02:36 PM
Don't do it, you will break the studs and then you will have a hard time getting them out, this could require splitting the case again.
Mark McClure 09-23-2009 03:03 PM
Ok thanks John and MCA,
The leak happened after a full rebuild when I had the engine on the stand to replace the clutch, a year later, I changed the seal but immediately had a small leak from the bottom of the seal at the seam. This was only from the oil that seeped to behind the seal while the engine was sitting. So I changed the seal again....all seamed fine. Until it was started. Only a small drip, seams to be when it sits rather then when running.
It could be from the crank but until drop the engine I have no way of knowing. Just getting my optionsready before dropping the motor.
Mark......
