MFI linkage wear: ball or cup?
Hi all,
since the cups of the MFI linkage seem to be obtained more easily than the ornaments with the balls, does it make sense to replace the cups if I experience wear. Or are the balls the pieces that typically show wear? (or both....)
Regards
Dennis
_____________________________
1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild!
Old 09-28-2009, 01:59 PM
Loose nut bhind the wheel
My experience has been the cups wear more as they are softer metal but you have to keep your balls greased.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 09-28-2009, 09:07 PM
OK, thanks ED. I've ordered two new cups (right and left thread) as a trial and will post the results (reduction of play) once I've fitted them
Rgds
Dennis
Old 09-28-2009, 11:19 PM
dtw dtw is offline
GAFB
Rgds
Dennis
I installed a complete set of new linkages from Supertec. While before I had a lot of popping and farting through the intakes at idle, my car now idles like an EFI engine.
Several BMWs
Old 09-29-2009, 06:02 AM
Dave, I've checked the Supertec site, thanks. Did you get the results from installing the new cups & bars only or also the ornaments with the balls on them? (why does this sound a little odd )
Dennis
Old 09-29-2009, 01:23 PM
dtw dtw is offline
GAFB
Dennis
This was just from installing the new linkages - the 'cups & bars'. The balls, they seemed to be in good shape.
Several BMWs
Old 09-30-2009, 07:44 AM
Tags
mfi linkage wear
