-   -   easiest way to tell... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/502398-easiest-way-tell.html)
Skytrooper 09-30-2009 03:02 PM
...if carrera tensioners have been installed. Is there a way to tell without opening the engine (cam) ?
Fast Corners 09-30-2009 03:19 PM
There is a very easy way to tell. If there is a tiny little oil line that comes off of the oil line to the cam towers and connects to the face plate of the chain boxes then you have carrera tensioners in your car. Here is a picture of the installation on the right side of the motor (credit Pelican Technical Article).
http://forums.pelicanparts.com/uploa...1254349097.jpg
Fast Corners 09-30-2009 03:28 PM
You can see the oil line better in this photo (courtesy Jaybird's rebuild thread)
http://forums.pelicanparts.com/uploa...1254349647.jpg
