-   -   Opinion on using case sealant between head and top of cylinder (http://forums.pelicanparts.com/911-engine-rebuilding-forum/502551-opinion-using-case-sealant-between-head-top-cylinder.html)
aadrew10 10-01-2009 11:11 AM
Hi,
I have 98mm nikasil pistons and cylinders. They cylinders do not use a head gasket. I would like to know any thoughts on using a small amount of case sealant on the head just like what is used for the cylinder base gasket, as well as your reasoning.
Thanks,
- Andrew
Flat6pac 10-01-2009 11:31 AM
The cylinders are Carrera so you need to torque to 15ft# then go back again, hit 15 and then 90 degrees with the torque wrench
There is a bevil on the Carrera cylinders where they meet the heads and youre torqueing to the Carrera spec.
Bruce
Eagledriver 10-01-2009 01:50 PM
I wouldn't use sealant here. It hardens and then will crack when the heads heat up and cool down. It might not hurt but I wouldn't take the chance.
-Andy
88-diamondblue 10-01-2009 04:28 PM
+1 with Eagledriver
The surfaces were designed to seal by just contact and pressure.
