Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Originally Posted by 911 tweaks View Post
wow... and wow again... especially if we are to now think to NOT down shift to aid in braking... I recall how most of the porsche race movies they down shift... maybe the key is that they are 100% race motors and only need to last the 1 race...
Great info here & thanks for sharing!
Bob
That, and I bet if you had telemetry on the car it would indicate that the driver heel-toed the downshift and was hard on the brakes the entire time... i.e. never used the engine to assist in the braking, just downshifted to ensure they were in the power band once they got back onto the gas.
Note to self, add ARP rod bolts to the eventual rebuild budget... or better rods & rod bolts. 1 more step down the slippery slope, but if I'm going to do it right then I'm going to do it right.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods... and looking for my next upgrade.
Old 10-27-2009, 09:20 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #61 (permalink)
I was on another thread last night that addressed stretch bolt tightening. If you used a torque wrench and not a form of stretch measurement, couldn't you trace this failure back to that? The thread said that even when the nuts were torqued to spec the bolts were not at their proper stretch. It sometimes took far greater torque to get the bolts to their proper stretch measurement.
I read with interest as I am in the middle of a 3.2 SS build. I know from years of motor cycle racing, which use a similar two-piece case clamped crank assembly, that the bottom end is king. Looking forward to your re-build thread.
Lindy
Old 10-28-2009, 06:35 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #62 (permalink)
No Expert
jgparker's Avatar
Hi Lindy,
I did the Wayne Dempsey Rod bolt torque procedure to the letter, so the rod bolt torques can't be too far off.
The interesting thing was Kevin Jeannette (935 and 962 engine king at Gunnar Racing) said forget all other methods. Torque all the nuts to 10lbs then 20lbs then 30 lbs and finally to 40 lbs. He's built hundreds of racing engines, including Sebring and Daytona winners, so he might know what he's talking about. He probably was talking about ARP or Titanium rods though.
Check out this engine shop. The room had more titanium than an SR71.
All photo's from Gunnar Racing secrete location in Florida.
Thanks,
JP
-- Engine rebuild project, No longer running so great
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too...
Old 10-28-2009, 05:32 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #63 (permalink)
Walt Fricke's Avatar
No doubt there are many ways to skin the rod bolt torque cat. No doubt Jeanette uses a lubricant he trusts when torquing. Pauter doesn't give a stretch figure with their rods (which come with bolts), though they have one if you ask for it. And I've not seen a stretch figure for factory bolts. And then there is the angle method. All ways to achieve the clamping force that a certain amount of bolt stretch gives.
But the bolt stretch method is not really difficult, and the tool for measuring is not expensive. Plus, with these good aftermarket bolts, you can remeasure at rebuild time and may be able to reuse the bolts - which is no small cost savings.
Neat photos.
Walt
Old 10-28-2009, 10:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #64 (permalink)
Changing from rod bolts to chain tensioners, I notice that both of the engines in the first picture do not have oil lines to the tensioners. Are they running a mechanical tensioner? If so, what type? I see in Pelicans catalog that these are available and cheap, a lot less than the oil fed pressure units. Again, coming from motorcycles, adjusting cam chains is part of life. Am I missing something? Also, the engine on the left in the first pic looks a lot like whats sitting on my stand although I'm sure it's quite different inside.
Lindy
Old 10-29-2009, 07:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #65 (permalink)
304065's Avatar
My guess is that they are solid tensioners-- but these are unsuitable for anything other than race engines.
John C.
'66 911 #304065
'71 911E PCA H-Stock Club Racer #806
Ex-'88 Carrera (Sold 3/29/02)
Old 10-29-2009, 08:33 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #66 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
kenikh's Avatar
FWIW, I strongly believe that the most reliable solutions are the 930 tensioners w/ safety collars.
Kenik
- 1969 911S
- 1965 911
Old 10-29-2009, 08:53 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #67 (permalink)
OK, I understand the fix it an forget it mentality. Why would the solid tensioners be suitable for racing only? Is it that you would have to add cam chain adjustment to the maintenance to-do list? The chain box cover gaskets are cheap and the time needed to pull the covers and adjust the chains seems minimal. Seems to me this is by far the safest way to keep your valves out of the piston tops. Maybe that's why race motors use it?
Lindy
Old 10-29-2009, 09:51 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #68 (permalink)
I noticed the lack of extra tensioner plumbing also.
I'm with Kenik on this one.
And these may be engines built to be period correct. The Carrera tensioners came in with the '84s, and they may well be older engines.
Walt
Old 10-29-2009, 11:55 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #69 (permalink)
Send a message via AIM to smokintr6
From the pictures above, what is the 4 cam engine with what looks like watercooled heads, and air cooled jugs? I would have instinctively guessed 959, because the parts look very "production-esque"... but I looked at some pictures, and the offset alternator doesn't quite fit in. Is it from a 962?? I'm going to go out on a limb and say that might be the most expensive, or at least rare unit in the room.
And as far as mechanical tensioners go...I think most people's heads woul explode if they had to worry about a service like that. On a race engine with a 50 hour top end, I would imagine the chain adjusting service interval takes care of itselft from simply taking them apart and reinstalling. I don't have first hand experience with them, but I can't imagine that the chains stretch very rapidly. Would be interested to hear from someone who is actually using them.
Old 10-30-2009, 05:58 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #70 (permalink)
I understand the "period correct" thing but if that were so, the chain box covers would not have an oil passage that's been plugged. I like the idea of mechanical adjusters; too many things can go wrong with anything automatic like pressure fed adjusters. Does anyone have any first hand experience with the mechanical adjusters and can you add your two cents please? The pressure fed kit is up to $750 now. That's pretty pricey for what seems to be non issue.
I know that if you're going to just drive your car and not pay that much attention to things, sure the pressure fed stuff look like a good way to go. My case is very much different as I like to monkey with the car as much as drive it.... sad but true.
Lindy
Old 10-30-2009, 09:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #71 (permalink)
Noob autocross junkie
What motor above has the alt on the side like that?
-Kyle
www.alphahero.net
1980 911SC Coupe - Bitz EFI, MSD 6AL-2, Euro Racing Headers, M&K 2-2 exhaust.
Old 10-30-2009, 10:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #72 (permalink)
Kevin is a very busy guy but he usually replies to emails in the very early morning.
I'd email questions about what rod bolts he uses and stuff like that.
When I worked there he used all origonal factory porche racing parts and I saw plenty of gorgeous mirror polished titanium factory rods from 935's and 962's when he was building those engines. I think those were Pankel rods.
I think I remember reading he used Pauter rods in the Rat motor on his website.
His facility is a totally amazing Porsche place... The pic on the top of his homepage is a view in the seperate museum building.
Gunnar Racing
A very cool place to be in S. Florida in many ways, and it feels like they keep it in the upper 60's in there to help preserve the cars and tires.
Old 10-30-2009, 11:16 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #73 (permalink)
Originally Posted by jgparker View Post
This is the way I'll remember it, as a great fun and fast engine that never let me down until then end, rather than the pile of scrap now in my workshop. JP
How many hours/miles did you get out of it?
82 Euro SC
PCA E stock
Gone
92 C2
Old 10-30-2009, 06:17 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #74 (permalink)
No Expert
jgparker's Avatar
I don't remember seeing a single set of pressure fed chain tenstioners at Gunnar. Kevin is not a big fan of them. He told a long story about them destroying a bunch of race engines before the factory figured out they were causing problems. It has nothing to do with looking period correct. He said he's thrown away a pile of them. The ones I saw had turbo tensioners, not the solid ones. There is a set in one of the pictures above.
If I remember right, that funny looking water cooled engine is for a 962, and yes, its worth more than my house.
I got about 50 hours and 6 years out of my engine before it let go.
JP
Old 11-02-2009, 03:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #75 (permalink)
What are Turbo tensioners? Evidently, they are not pressure fed. How would I source these?
Lindy
Old 11-03-2009, 07:54 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #76 (permalink)
Turbo tensioners are term used to describe the last version of non-pressurized chain tensioners used from 1978-onward.
Provided they are installed with the wide idlers and tensioner guards, they are OK to use. I strongly recommend the pressurized ones for street cars, though as they are very reliable,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-03-2009, 08:59 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #77 (permalink)
No Expert
jgparker's Avatar
I do want to clarify one thing, my cars all have pressure fed Carrera tensioners. For a street car, they are probably the most reliable solution. Racing is probably a different story.
JP
Old 11-03-2009, 06:01 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #78 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
So if I have a '78 SC I have "Turbo" tensioners?
Lindy
Old 11-04-2009, 06:19 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #79 (permalink)
Lindy
Thats what those cars came with from the Factory.
The Carrera pressurized ones can be ID'ed by the small oil line running down across the cam chain covers.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-04-2009, 09:01 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #80 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
