Looking for spark plug wire bits (wire, boots, etc.)
I'm looking for brands/suppliers of plug wire components (wire, boots, etc.). I've searched here and on the web and I'm not having any luck. Any help is appreciated.
Tim K |
MSD sells high quality low resistance 8.5mm spiral core wire, connectors, and kits with all the stuff including a connector crimper tool you use in a bench vise you need to make your own wire set.
at least they used too... |
NAPA has it for some applications...custom wires..
Bruce |
Is there any particular reason to go with special ignition wire when using a Delta Mark 10b CD ignition box? Or will the stock, copper wires do?
Thanks! |
Thanks guys.
Tim K |
| All times are GMT -8. The time now is 04:38 AM. |
