Tim K's Avatar
What are these fuel fittings called and who makes them?
As the title reads, I'm looking for fitting like this which are intended to be pressed in. I would like to avoid tapped holes for NPT threads or for O-ring Boss fittings. This is problematic when trying to use a 90deg fitting and you need it in a particular orientation. What I'm really after is names of manufacturers or suppliers as I'd like to buy in bulk. Any help is appreciated.
Pic. from the internetz:
Tim K
Old 10-23-2009, 10:06 AM
Parker-Hannifin is one source.
Fluid Systems Connectors Division - Parker
A large industrial supply house like Grainger or McMaster-Carr might also carry them, but for OEM quantities, try the manufacturer.
BTW, these are known as brass flared or hose fittings.
Sherwood
Old 10-23-2009, 12:58 PM
