-   -   ovesize bearings to a 2.7 block? where? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/507505-ovesize-bearings-2-7-block-where.html)
JYRI ERAMAA 10-28-2009 07:16 AM
is there a company that sells oversize main bearings for a 2.7 block?
havent found any...is it worth the hassle?
the block is othervise good, but my guess is that it needs some machining.
the block is in stock size.
i would have a possibility to use a 901/02 block or a 901/09 block instead...
for a screamer project...with 90mm high comp slugs.
what would you do?
SmileWavy
thanks for any infohttp://forums.pelicanparts.com/uploa...1256739355.jpg
4sd911 10-28-2009 09:00 AM
If your looking for oversize bearings for a ground crank they are available here and other suppliers. If you need oversize for a line bored case I believe they can only be purchased from the Porsche dealer.
JYRI ERAMAA 10-28-2009 09:20 AM
Hmmm, its for the block. So i have to ask, from Porsche dealer then. Thank you! :-)
Flat6pac 10-28-2009 01:30 PM
Thats not a 2.7 block..
Bruce
J P Stein 10-28-2009 04:29 PM
Bearings for an oversized mainbore OR an undersized crank are priced like gold.
I have a perfect .01" under crank that would make a nice lamp.:mad:
JYRI ERAMAA 10-28-2009 10:47 PM
Bruxe is right. Thats my 68 s block. But the whole thing sounds like 911 blocks are not so great to rebuild... :-(
ChrisBennet 11-02-2009 10:22 AM
Instead of increasing the size of the mains and using oversize bearings ($$) you would do better to just have the case resized.
Resizing = taking a little off the case halves and reboring the shaft holes back to standard.
Competition Engineering or Ollies can do it for you.
-Chris
Steve@Rennsport 11-02-2009 11:49 AM
-Chris
Chris is right on,....:)
Thats the proper way to fix these cases.
JYRI ERAMAA 11-02-2009 03:05 PM
great to know, but im located in europe :-( sadly. i have to ask from the machine shop. if they can do it. thanks again. maybe getting a different block would be the best thing?
