-   -   Resealing and studding a 3.2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/510383-resealing-studding-3-2-a.html)
Flat6pac 11-11-2009 06:36 PM
The newest of treats is to see what others have done when you open an engine.
This had a broken stud but lots of sealants that didnt belong. Lots of sealant on the cam chain boxes, held like glue, regular nuts where nylocs belong.
Bruce
http://forums.pelicanparts.com/uploa...1257993114.jpg
http://forums.pelicanparts.com/uploa...1257993196.jpg
http://forums.pelicanparts.com/uploa...1257993266.jpg
http://forums.pelicanparts.com/uploa...1257993352.jpg
88-diamondblue 11-11-2009 07:48 PM
Wow!:eek: Amazing to me what owners or mechanics do to these engines. Steel studs going back in place of those Dilavar studs?
Flat6pac 11-12-2009 04:18 AM
Steel going back on the bottom but I do it after putting the P/C s because its much easier to place the snap rings on the pistons.
Did you notice the single 993 dilivar in the picture?
Bruce
Flat6pac 11-12-2009 04:02 PM
Replacing the intermediates, but its always expected, this is typical.
Pressure test for a couple days make sure its good, but I ll know by morning.
Bruce
http://forums.pelicanparts.com/uploa...1258070473.jpg
http://forums.pelicanparts.com/uploa...1258070564.jpg
Carrerax 11-14-2009 04:32 AM
Bruce,
Can I rent that pressure tester for a week? Thanks, Mark
Flat6pac 11-14-2009 01:03 PM
We want the crank to survive, I would rather loose a cam than a crank and all that goes with it when it happens, this is interesting the reducer to the cam oil bar.
Bruce
http://forums.pelicanparts.com/uploa...1258232152.jpg
Flat6pac 11-15-2009 01:32 PM
Valve job, the heads are back from the shop. I was suprised as the engine had 2 broken studs over its life and the heads didnt need a flycut to square up with.
The case cleaned well, inside and out.
Bruce
http://forums.pelicanparts.com/uploa...1258320623.jpg
http://forums.pelicanparts.com/uploa...1258320694.jpg
Flat6pac 11-19-2009 04:21 PM
This was a pretty good couple days, blew every nook and cranny out and started putting it back together.
Bruce
http://forums.pelicanparts.com/uploa...1258675342.jpg
http://forums.pelicanparts.com/uploa...1258675412.jpg
Carrerax 11-19-2009 05:58 PM
Looks great Bruce!!! Keep the pictures coming!
onboost 11-20-2009 08:26 AM
Ahhhhhh, the Green monster hanging out in the background. She's still purdy!
P-
Flat6pac 11-21-2009 09:34 AM
New return tubes always look attractive.
Cams came in at 1.30mm
Bruce
http://forums.pelicanparts.com/uploa...1258824305.jpg
http://forums.pelicanparts.com/uploa...1258824394.jpg
Flat6pac 11-24-2009 06:19 PM
Im trying to get as much off the floor as I can. The more off the floor the more complete it becomes. I had some fun today with the studs..but the exhaust is located and locked down.
The injection isnt pretty yet as the injectors are out being cleaned so all the rails are hanging loose.
Bruce
http://forums.pelicanparts.com/uploa...1259115486.jpg
http://forums.pelicanparts.com/uploa...1259115533.jpg
LeakProof 11-24-2009 06:33 PM
Bruce,
Where did you send your injectors for refurbishment?
Leakproof.
Flat6pac 11-26-2009 11:49 AM
The injectors came back Wednesday for the evening. Once installed I started taking things off the pile and sticking them back on.
I have to put it back on the table as front right sheet metal and clutch assembly has to be put back in place.
Still have to clean the fan and housing but my compressor is too small even for a small cabinet.
Bruce
http://forums.pelicanparts.com/uploa...1259264800.jpg
http://forums.pelicanparts.com/uploa...1259264870.jpg
http://forums.pelicanparts.com/uploa...1259264927.jpg
Flat6pac 11-27-2009 03:24 PM
I needed the engine off the engine stand and on the table so I could get the clutch and front of the engine back together.
Flywheel, clutch pkg, bell studs replaced, sensor pickup dialed in to .8..
Once I get the fan cleaned, this will be ready to go home
Bruce
http://forums.pelicanparts.com/uploa...1259364189.jpg
http://forums.pelicanparts.com/uploa...1259364260.jpg
freddie 11-27-2009 08:03 PM
Loved the pics !
Flat6pac 11-30-2009 01:25 PM
:)Re: the phone conversation..
I was wrong about the one you commented on. Your comment was on the one in the background.
This is the finished product from the boxes you brought here.
Enjoy the looking,
Bruce
http://forums.pelicanparts.com/uploa...1259616069.jpg
http://forums.pelicanparts.com/uploa...1259616122.jpg
http://forums.pelicanparts.com/uploa...1259616184.jpg
VMAX1 12-03-2009 07:49 PM
I knew my engine I was working on would look that good. Oh, that is mine. thanks
Flat6pac 03-23-2010 07:03 PM
this is the one, 1987 Carrera Convertible last November
Bruce
