gijams's Avatar
oil leak & car stops running
I finished the engine rebuild and had no leaks or problems. Then I jacked up the passenger side of the targa and rebuilt the front brake caliper. The car was on the jack for a couple of weeks. Now their is a intermittent leak around the top of the oil cooler but I can not see where. The oil also leaks into the heat exchanger.
Next problem, if I hit a sharp bump the car stops running. Nor lights etc. the fuses are fine. After it sits for a few seconds it starts up and runs fine. Is the probel in the key switch on the dash board?
Old 11-13-2009, 03:57 PM
E Sully's Avatar
If it's a 3.2 it might be the DME or the DME relay under the drivers seat. I'd try a new relay first, they have a tendency to fail. It's always a good idea to have a spare one in the car. I doubt it has anything to do with the wiring or ignition switch. My DME failed, which I confirmed by putting it into another car. Mine would't start at all till I had it rebuilt.
Old 11-14-2009, 05:05 AM
Hi,
If the problem started after your engine rebuild, you may check all the connectors in the engine bay. One contact may have come loose, causing a stop of ignition or fuel supply. Also check the famous ground straps (engine, gearbox, battery !) if they are tight as well.
DME relay of course is a good candidate as well.
Good luck,
jens
Old 11-15-2009, 06:14 AM
