Positioning of large saucer shaped washers on engine and trans mounts?
It seems I'm missing my reassebly pics on the motor and trans mounts (71 911 e). It looks from the manuals that they are installed with the saucer facing away from the mount. In other words the low point is closest tithe mount and the washer flares away from the mount.
Is this correct? Also it shows one washer above and below on both engine and trans mounts but I only have six from my car. Is one washer above and one below the correct application? Thanks |
You should have 8. Flares facing out is the softer option flares in is harder.
I was pretty meticulous about my notes and photos and show only the two bottom washers being present as well. Anybody else have this setup on their type 911 trans? http://forums.pelicanparts.com/uploa...1260229678.jpg http://forums.pelicanparts.com/uploa...1260229708.jpg |
| All times are GMT -8. The time now is 07:00 PM. |
