Phrog's Avatar
Mag Engine case sealing
I have looked at many postings on how to clean engine cases. What I have not seen is there any recommended methods of sealing the mag case after cleaning to protect that great new finish??
Kevin
84 911 Carrera
71 911E Vintage Race Car
25 Ford Explorer ST
20 Subaru Crosstrek
Old 11-15-2012, 05:12 PM
Hi Kevin,
While its not exactly pretty, Tectyl is the best stuff to prevent corrosion on those mag cases.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-15-2012, 05:14 PM
AV8TOR
What version of Tectyl should be used on mag cases??????
When I goole Tectyl, several vendors and several different ###s pop up.
Thanks and Cheers, Tom/AV8TOR
Old 11-22-2012, 03:09 PM
Steve, what do you use on aluminium cases? An engine builder I know suggested VHT clear coat but then I read a post by Grady Clay that pretty clearly said DO NOT paint the case with anything.
andy
Old 11-22-2012, 04:19 PM
Check out Gibbs
Gibbs Brand penetrant
Old 11-22-2012, 06:56 PM
andy
Andy,
I don't coat these cases with anything; these are not as prone to corrosion and any coating partially blocks heat transfer (cooling).
Just get it clean and maintain it,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-23-2012, 01:14 AM
