-   -   Cross drilling replacement? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/513300-cross-drilling-replacement.html)
tadd 11-26-2009 10:04 PM
Being well aware that cross drilling the crank for high rpm oiling of the rods is a proven mod, I still have trouble loosing bearing area to grove either the bearing or the crank journal.
So assuming the oiling difficulty is truly due to the torturous path combined with the crank spinning at speed...
Why could one not just drill a 1/4" hole down the length of the crank and press fit a plug on the open end?all the rod journals 'look' like they pass thru the crank centerline - including the two end 'feed' bearings (which are already extra wide). A co-axial hole won't have a flow problem
with the crank spinning and it's one long hole thru the unhardened material... And no loss of bearing area, AND best of all, the material removed won't weaken the crank.
I mean, it worked on the early camshafts - why not here?
Flieger 11-26-2009 10:32 PM
Are you talking about the same oiling method as the 917 crankshaft? Oil fed into axial drillings in both ends of the crank, meeting in the middle? This reduced oil pressure needed significantly due to not fighting centripetal force.
I always assumed the reason this was not done on 911 cranks was that the clutch on one end and the accessory/fan pully on the other blocked the way for a drilling. The 917 had the advantage of the central, lower power take off shaft from the center gear, which also drove the fan, distributors, and camshafts.
tadd 11-26-2009 10:45 PM
Didn't know that about the 917. Is it literally like the early center lube cams... I.e. Filled on one end thru a ceramic thrust seal?
I was just assuming to drill and plug the end that was started from. Given that one only need to intersect the other drillings, I would think the operation could be done on a long quill drill press and use the flywheel to clamp to the table. If you wanted to get fancy, a pipe plug could be set at a depth so that the pully bolt acts as a lock.
I would think the 'stock' fill from the end grooved bearings/crank would still be just dandy...
Flieger 11-26-2009 10:52 PM
http://forums.pelicanparts.com/uploa...1259304475.jpg
http://forums.pelicanparts.com/uploa...1259304573.jpg
http://forums.pelicanparts.com/uploa...1259304678.gif
http://forums.pelicanparts.com/uploa...1259304702.jpg
I think the 66mm stroke 911 crankshaft has enough journal overlap for center-drilling but the later, long stroke cranks with their offset-ground journals do not have enough overlap.
TimT 11-27-2009 05:28 AM
Another approach to crank oiling improvement it shown in this thread
http://forums.pelicanparts.com/911-engine-rebuilding-forum/153351-trick-extended-high-rmp-survival.html
Henry Schmidt 11-27-2009 02:55 PM
The best way to cure the inherent bad oil of the Porsche crank is to use modern crank construction.
The Supertec Super Crank does just that.
We feed every rod journal from it's own main bearing. Each feel is bored to accommodate the additional oil flow.
http://forums.pelicanparts.com/uploa...1259362385.jpg
http://forums.pelicanparts.com/uploa...1259362415.jpg
