-   -   Any NYC metro area Pelicans have a Cylinder head CC'ing set up? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/514031-any-nyc-metro-area-pelicans-have-cylinder-head-ccing-set-up.html)
jwasbury 12-01-2009 06:16 AM
...and willing to lend a hand? I've just gotta know precisely where I will be at for CR on my '79 930 engine build.
If nobody around can help, I guess I'll be buying another tool that will see very little use once this project is completed.
nocarrier 12-01-2009 07:24 AM
All you need is a burette, a piece of plexi-glass cut to the size of the combustion chamber with a small hole in it, and a little bit of grease to seal the plexi-glass to the head. Get a nice thick piece of plexi-glass.
You could probably find a burette and stand on flea-bay.
Make sure the head is nice and level and take your measurements. Use a thin oil. Marvel mystery oil comes to mind.
-good luck!
-Adam
