38mm Ex Ports but Gaskets are 36mm?
I was all excited as I near completion on my 2.7RS rebuild when I was examining my Exhaust Ports, they are 38 mm as measured with my caliper. The openings on the heat exhangers is 35mm and the gasket is 36mm....is this correct? Should I be looking for a larger exhaust gasket?
Thanks, Nabil
'71 S track car, 2.7L & Webers forever! |
Many of the 2.7 heads have recesses for the blow proof insert.. After the copper clad gaskets, most are interchangable until Carrera which are several mills larger.
Bruce |
