-   -   Wayne Top Engine Picks (http://forums.pelicanparts.com/911-engine-rebuilding-forum/515268-wayne-top-engine-picks.html)
T Malovich 12-07-2009 08:07 PM
I am in process of collecting the parts for Wayne's 2.2 -> Upgrade for my tired 1971 2.2T. I have the E pistons and cams along with freshly rebuilt heads, still on the hunt for a clean 2.7 crank, (the hunt is half the fun) any suggestions on other parts that will improve the reliability and the performance.
we are just a few weeks away from dropping the upgrade parts along with the block to the Porsche Wizards for the rebuild.
This car has been a blast to own and drive and we want to keep the car running strong and reliable for many years to come.
Tony
joetiii 12-12-2009 04:54 AM
Sounds like a fun project. I think Wayne's book gives great suggestions on this and seeing that no one else has responded here, maybe you should post over on the EarlyS site. There are more small bore lovers over there :)
Wayne 962 12-12-2009 11:04 PM
Hi there. I really feel that there's almost nothing that's not included in my book? Just follow the procedures there (especially the prep required for the case), and you should be good-to-go!
-Wayne
777joee 12-14-2009 09:57 PM
Thank you
-Wayne
That is what I did with my first 911 motor build. I'm not new to rebuilding a motors but I had never rebuilt a 911 motor. I bought and read Wayne's book cover to cover more than once. Between the book and help from a lot of good folks that post here it was not easy but not hard either.
I rebuilt my 3.0 to the High Performance 3.0L specs with the exception of keeping the stock 9.3:1 compression. 234.7 Hp@5750 and 225Ft/lb torque@4850.
Thanks Wayne!
MrPerkles 12-15-2009 01:10 AM
Im doing the 3.0 rsr but with EFI ;)
gearheadgreg 12-16-2009 02:28 PM
Personally, I think that optimizing the heads and cams are key to the performance you want. And then, depending on the cams, the compression comes into play, etc etc. Waynes book covers it pretty well, and head porting could take another series of books, so research at your leisure!
