-   -   79 911 sc 3.0 crank numbers?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/516104-79-911-sc-3-0-crank-numbers.html)
slick41cars 12-12-2009 09:04 AM
What do you think? Can i use this crank on a street engine with just a buff. mains, 1-7 59.9795 mm rods
59.9719 52.959
59.9770 52.971
59.9795 52.969
59.9744 52.959
59.9744 52.931
59.9668 52.931 waynes book says says shaft ware limits. mains
56.960 rods 52.960
this was the min not the max
thanks.
tom1394racing 12-12-2009 10:19 AM
Use this format as a guideline for wear limits on the journals.
Crank should also be checked for run-out. The limit is 0.02mm
A quick "ring check" will tell if it is cracked.
http://forums.pelicanparts.com/uploa...1260641951.jpg
slick41cars 12-12-2009 11:21 AM
Thanks for the info, looks like a little under on the rods. gess i will send it out after xmas. good way to spend my tax return.
