Set the valves
Last on the road in 2003, set the valves and get it started...
Rocker shafts moving off location, installed backwards and off proper location http://forums.pelicanparts.com/uploa...1260658250.jpg http://forums.pelicanparts.com/uploa...1260658441.jpg http://forums.pelicanparts.com/uploa...1260658555.jpg |
Bruce - Looks like that one could use a good rebuild. Be interesting to see any other probs.
Rocker shafts were all in place on 4,5, 6, side but 2 nuts and stud fell out at me so it will be a while before I play with the CIS.
Bruce http://forums.pelicanparts.com/uploa...1260758180.jpg |
my #3 shaft came out. made a heck of a racket, but nothing broke. i had a hard time getting it tight. i guess i should not have put off the valve adjustment
The last guy left a space there......
Bruce http://forums.pelicanparts.com/uploa...1262386112.jpg all the studs pulled easier than some do http://forums.pelicanparts.com/uploa...1262386173.jpg getting it back together http://forums.pelicanparts.com/uploa...1262386314.jpg finally, today, 1/1/10 Still need to resolve the scavange to the thermostat http://forums.pelicanparts.com/uploa...1262386396.jpg http://forums.pelicanparts.com/uploa...1262386471.jpg |
finally got into the 50 s this weekend so I got it off the table and the trans mated yesterday so I m hooking up to get this running
Bruce http://forums.pelicanparts.com/uploa...1263674046.jpg http://forums.pelicanparts.com/uploa...1263674097.jpg |
Well, considering it hadnt run is 6 years, the fuel distributor was frozen, rockers were wrong installed, not tight, and broken, then broken studs on the right side. Well, its ready to go home.
Bruce http://forums.pelicanparts.com/uploa...1265219698.jpg |
| All times are GMT -8. The time now is 08:07 PM. |
