efhughes3's Avatar
New wrist pins compatable with used rod bushings?
I'm seriously considering a bump in displacement and compression. I'm looking at a set of Mahle 98mm P's and C's or going to a JE/Nickies combo of 98's with some more compression-probably 10.5:1.
I rebuilt my engine two years ago-about 7,000 miles on it. I used my 3.2 P's and C's after them getting a clean bill of health by George @ Ollie's. The rods were reconditioned at that time to factory specs.
My question is, can I get away with using the rods as-is with the new wrist pins that come with the JE's, as I really don't want to open the case, as it was/is new.
PS- I'll make use of the extra plug holes I had machined into the heads when they were rebuilt as part of this-probably an Andial splitter and a 964 dizzy.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-21-2009, 07:15 PM
Almost Banned Once
sc_rufctr's Avatar
After 7,000 miles you should be good to go as long as the rod bushings look good.
If there are any marks or scuffs I wouldn't use them... Nice even wear with a uniform haze is what you want to see.
- Peter
Old 12-21-2009, 09:01 PM
BURN-BROS's Avatar
If the bushings are within spec there is no reason not to. Prep the bushing with a few passes of a red scotchbrite pad and your good to go.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-22-2009, 05:57 AM
efhughes3's Avatar
Thanks guys. Of course, re-use would be subject to inspection. I was looking to see if I was nuts to even consider this. I appreciate the replies.
Old 12-22-2009, 08:20 AM
