piston to cylinder clearance
I have a set of 911S 80.5mm Mahle pistons to go with my
80mm biral cylinders (to be resized.) What clearance
should I go for. Tech specs for 67S show minimum clearance
at 0.45mm but 68S has 0.35mm.
andy
Old 12-21-2009, 05:09 PM
Those numbers are too big by about 10 times.
-Andy
Old 12-22-2009, 02:14 PM
Andy, you are right.
But the question still stands, should I be going for 0.045mm clearance or
0.035mm clearance or more or less. I can size them anywhere I want given
that the pistons are about 0.5mm larger than the bore at this point.
andy
Old 12-22-2009, 02:49 PM
I like .40mm or .0015 for Mahle forged pistons.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-22-2009, 03:40 PM
I believe the wear limit is .004 inches. Personally I like to set them to .002 inches if I have the choice. I don't have the experience of Steve however.
-Andy
Old 12-23-2009, 03:17 PM
Tags
cylinder resizing
