CR change by shaving heads
Anyone have a formula(s) for calculating what you'll get for a new compresison ratio by knowing original compression ratio and motor size and shaving some value of heads?
Stroke volume= Vs
Combustion volume = Vc CR (compression ratio) = (Vs+Vc)/Vc (if you know the CR you can determine the Vc) Shaved height= H delta Volume trough shaving = Vd= (0.25**Dē)*H =3.14 and D is cylinder diameter New Cr = (Vs+(Vc-Vd)/(Vc-Vd) hope this will help (and this is correct...) |
Yes that make sense... I was forgetting Vc in the numerator of CR in what I was doing. Below is example for 993 for shaving 0.010" to 0.020" from heads. Frankly I was surprised at how much CR went up.
http://forums.pelicanparts.com/uploa...1261574450.jpg |
yes, the effect goes up exponential with the CR. I was doing this calculation on a 3.3 turbo with a CR of 7.5 and there the effect is not that big.
And then there is valve to piston clearance and deck heighth checks...
| All times are GMT -8. The time now is 06:44 AM. |
