Apprentice 911 Mechanic
1979 911sc
Has any one heard of using a 3.2 crankshaft in a stock 3.0 engine? If so what work and parts are required?
Greg |
In a nutshell, you need the 3.2 crank, rods, pistons and bearings.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
thank you! Can you use the 3.0 cylinders,rods and pistons?
The 3.0 has different bearing sizes for the rods and the pistons have different pin sizes. You need a crank and rods for 3.2 and you can rebush the small end of the rod to accept the 3.0 piston but then you might have clearance problems in the heads. The 3.2 piston is visually different than the 3.0
Bruce |
