-   -   Does "most" of a 2.7 gasket kit fit a 3.0?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/519325-does-most-2-7-gasket-kit-fit-3-0-a.html)
Mark Henry 01-02-2010 06:55 AM
I have an opened 2.7 set does the bottom end fit a 3.0?
I know head gaskets are wrong.
Or not worth it, just flog it and buy new.
Flat6pac 01-02-2010 07:37 AM
everything fits except the 6 head gaskets,6 base gasket, large flywheel seal, and the 2 cam gasket with the 3 holes in it. All the items are available individually from our host..
Bruce
Mark Henry 01-02-2010 11:03 AM
The two cam gaskets do you mean cam plug 930-104-194-02-M17?
I'm just talking about the engine gasket kit here and I see
Cam plug
Head gaskets
Base gaskets
Pully O ring seal
Seal ring for the pressure switch
If that's it excellent! about a $200 savings for me!
Oh BTW it's a 79SC 3.0.
Thanks!
Flat6pac 01-02-2010 06:16 PM
cam gasket 930.105.197.05 2 each
The number you show is a cylinder base gasket but you need it
Mark Henry 01-02-2010 06:46 PM
Sorry I copied wrong number and I meant about 930-105-161-00-oem?
thanks for the cam gasket number.
