-   -   Head Studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/519649-head-studs.html)
Rich Rosenberg 01-04-2010 07:24 AM
Head Studs
I am rebuilding my 2.5 race motor and I am not sure which head studs to use. Has anyone had a problem with Supertec head studs? Any comments at all?
Rich
mppickett 01-04-2010 05:26 PM
I haven't heard of any problems with the Supertec studs. Henry does great work.
Eagledriver 01-04-2010 07:26 PM
If you are using a Mag case I'd use the 993 dilivar studs. If you are using an aluminum case then I'd use steel studs, supertech seem to be very good steel studs.
-Andy
