JoeMag's Avatar
Machine shop recommendation to clearance oil pump for carillo rods
Any recommendations on machine shops to clearance 964/993/gt3 oil pump for carillo rod use?
Old 01-05-2010, 05:40 PM
Mahler9th's Avatar
What are your geographic preferences?
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 01-05-2010, 06:40 PM
Drive it like u stole it.
jonesb930's Avatar
is this modification only necessary for 3.6L (long stroke) engines?
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 01-05-2010, 06:45 PM
JoeMag's Avatar
geographic pref would be someone near cleveland, ohio, but want it done right and i'm sure prices may vary enough to make up shipping charges.
Old 01-06-2010, 03:51 AM
CBRacerX's Avatar
This is not a whole lot of work, I did mine (using R&R Rods which are dimensionally similar to the Carillos) with a very careful application of a 4" grinding wheel. I found that _very_ little material needed to be removed. Since you will not know if they are cleared properly without having the case in hand, go local if you are not comfortable doing it yourself.
You can see what it took here: Another 3.6->3.8 Rebuild Thread... - only .5 mm removed.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 01-13-2010, 04:49 PM
