Before I reassemble the engine ...
I am rebuilding a 1972 2.4 MFI engine. I have it torn down and have parts ordered from Pelican to complete the rebuild.
As I am removing the parts, I am wondering how to clean them and prepare them before the rebuild starts. Should I plan on painting the parts? I am planning making the car a weekend driver, not a show car (although an occassional show is not out of the question). Does anyone have any suggestions on how to clean and prepare the following list of parts: 1. Cylinders 2. Case 3. Fan 4. Distributor base This project has been a long time coming. Now that the engine is out and torn down, I am getting excited to get this car on the road after many years in storage. I would appreciate any input that anyone can provide. Thanks. |
Lots of threads on cleaning stuff so search away on the details!
they can summed up, for the most part, as follows: CASE: By hand with chemicals or Soda blasted or Ceramic tumbling or all the above Cylinders: Scotch pad insides (maybe) depending on which expert says what you may grape hone or not Chemicals or soda blast outside Fan: bead blast (but you will need to take care of the center as it will rust after that) Dist. Base: Bead blast Everyone has their chemical of choice... mine are scent free mineral spirits and 90% isopropal alcohol in a spray bottle (buy it at wall mart for $1/bottle). MEK on the really bad stuff, but be warned that is some nasty nasty chems. -Michael |
Hey Michael,
Thanks for the information. I have done some digging in the forums here to find some great information. Unfortunately, as I dug deeper and found what COULD be done, I noticed that I will have to dig deeper in my funds also. There is one additional part that I could not find advice on: Exhaust and heater boxes. I would like to find some ideas on how to prepare these parts before reassembly. Any ideas? Thanks Donald |
I am not a fan of painting anything Porsche did not paint. Once the grease and grime is removed, what's wrong with what is left? The engine won't run better. Having said that, I did like the fact that i could soda blast (you can do this in your driveway if you have an air compressor and don't mind a white powder mess) the otherwise impossible to remove crud from a transmission case, with all those fins. Doesn't take long for much of it to come back, though.
You have the good exhaust system. I bet the exhaust parts, where exposed, have a nice rust patina. Going to be tough (or expensive, probably both) to do much useful with that, and I think whatever you do within reason is not apt to increase their life span. You could try a rust neutralizer and some high temperature paint. I've not had much luck with that stuff, but maybe others have. A high temperature paint might do some good with the heater boxes. They don't get as hot as the exhaust piping. I never could stop the rust on one of mine, though. Walt |
Hey Walt
Thanks for the input. You raise a good point: Why paint something Porsche did not paint? I will have to investigate the soda blast process. I have the compressor and the space outside to do the work. I am still considering what to do to the heater boxes. I will have to look around to see what others have done. Thanks Don |
The air blasting gun I have is very inexpensive. I sucked the baking soda straight from the bags of it I bought at Costco. This has to be the safest blasting one can do, as I could direct it at my fingers without damage to skin.
| All times are GMT -8. The time now is 04:36 PM. |
