-   -   993 Mechanical Rocker Conversion Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/522556-993-mechanical-rocker-conversion-question.html)
RSR.guy 01-21-2010 10:12 AM
Guys,
When converting 993 valve train to mechanical rockers, does the bushing oil hole stay in place...or do you remove it? (i.e. install a bushing that is not drilled for oil feed)
Cheers, Chris
BURN-BROS 01-21-2010 10:25 AM
They must be blocked.
RSR.guy 01-21-2010 10:31 AM
Perfect. Thanks Aaron!
BURN-BROS 01-21-2010 11:07 AM
No problem! Cheers!
