Rick
Powder coating on engine?????
Hi to all. Rick's rebuild is going well (so far!) Engine is apart, and I am getting it in boxes to send to Ollie's. MFI pump is on the way to Gus. My question is on powder coating the engine parts. I have already had the various bits of sheet metal done that surround the engine.
What about: (1) the chain covers? Inside and out? (2) the sheet metal that guides airflow between the cylinders? (3) the oil drain cover? (4) Upper and lower valve covers? (5) fan blades and housings? (6) are there other parts that are normally powdercoated? Will the powder coating resist oil sufficiently if it is on the inside of a part? The chain housing covers look like they are coated on the inside with something. The guy at the powdercoating shop said that magnesium parts sometimes emit gases during the powdercoating heat cycle. Any special things to consider here? Thanks in advance. Hopefully, I will learn enough during this process to help others in the future.
Rick 1970 911 E purchased in Stuttgart in 1973 |
If it were me....
1)- NO 2)- Yes 3)- No 4)- NO 5)- Yes 6)- Engine Mount Bar and Cover
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche Last edited by DUK; 01-24-2010 at 03:21 PM.. |
I'm here to cause trouble
I wouldn't do the fan - a good cleaning and clearcoat looks nice. Here are some recent examples.
![]() ![]() JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
E-85 sippin drunk
First off, if the guy you are thinking about paying to powdercoat your parts doesn't tape off the areas of the parts that should not be coated...RUN away from him. I would NOT have anything powdercoated that sees the inside of the engine. All of the parts above can be taped, so the powdercoat does not get on any surface that sees the inside of the engine. ... The Outside of the chain cases, valve covers, fan, and fan housing can all be powdercoated. On the fan, the tips of the blades need to be taped off so no powdercoating gets on there, otherwise you will run into possible clearance issues. I have both of my valve covers, fan, and fan housing powdercoated.. I did them myself and they look great as well as powdercoating free on the sides that see the inside of the engine.
again, if the guy who you are paying does not tape off the parts... run away!!! here are a few pics of the stuff i did.... If you see the high temp tape on the calipers... thats what needs to be applied to keep the powder off of the part that does not need coating... ![]() ![]() ![]()
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk Last edited by turbobrat930; 01-24-2010 at 09:35 PM.. |
Be careful about powder coating anything that might be a heat transfer part.
This is an air-cooled engine...if you coat (or paint) anything that would normally radiate heat...the engine might over-heat. I have seen ppl paint the cylinders of motorcycle engines with the wrong material, and the engine did not last for more than a few hours. Good luck Bob
Bob Hutson |
HawgRider has a point. Most bang for the buck is the fan housing and fan. I also do the upper valve cover. The lower valve covers have fins and do radiate heat, they cover the exhaust valves (more heat) and oil sits down there (more heat). Anything else, no.
Be careful what you paint on the fan and housing. The alternator is a close fit and paint will interfer. The ends of the fan blades and the center are other areas to avoid. ![]()
Old Tee all 911s sold |
GAFB
I do the cooling tin between the cylinders and around the engine perimeter. Holds up great if properly prepped. Generally speaking, I would not PC any surfaces facing inside the motor. Process excellence dictates that we do not open that can of worms. And yes, while PC does resist oil and most contaminants, it can flake off of oxidizing/outgassing/dirty surfaces. This is particularly true of Mg parts.
Several BMWs |
E-85 sippin drunk
As far as the fan shroud and the fan itself... old tee is right, and that was the point I was trying to make. There are several areas that are very tight clearances. These need to have NO powdercoating there, or you will be scraping it off to get things to fit back together correctly.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
valve covers, engine tin, fan and housing
did you also consider ca plating the screws, nuts, etc
