Gertvr's Avatar
Piston Pin to Small end bearing clearance question
Hi,
I am measuring clearances before assembly and I'm getting a little confused with the small end clearances for a '78sc 3.0l motor and hope get it clarified.
Wayne's book (pg 205) states:
Rod bushing / Piston Pin Diameter 22.020 - 22.033mm and;
Piston pin to bushing clearance 0.020 - 0.037mm with wear limit 0.055mm
What I am getting:
Rods - Pauter: small-end bush diameter 22.01164 (0.8666" from spec sheet)
Piston Pin 22.0025mm measured
Clearance .00914mm
Also the Pauter rods have less width in the small end i.e. 22.86mm compared to the 24.8 - 25.0mm in the book. Is this correct?
Cheers
Gert
2008 Honda S2000
2003 C4S (Sold)
1975 911 S with some small modifications
"Its good to plan your work, but its even better to do it"
My Gallery
Old 01-27-2010, 08:31 AM
Typically the rod bushings are honed to the correct clearance for the pins. I suspect these need to be honed. I'd send them to a capable machine shop for evaluation/honing.
-Andy
Old 01-27-2010, 10:07 PM
That is correct. It should be .01mm or a little less than .0005" inch. If it is a .001" inch you will hear the wrist pin knock.
Old 01-29-2010, 04:56 PM
Gertvr's Avatar
Cool, thanks for the confirmation. I will have it measured to make doubly sure.
Cheers
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 01-31-2010, 12:05 PM
pin fit
For performance/race clear. we set them up .0006- .0008 in. on a 22/23mm pin, for street use .0004 -.0005 in. any tighter and there is little room for lubrication. the same goes for the fit in the piston. the other important part of this is to have it checked on a proper fixture like a Sunnen rod machine where the total travel of the dial guage is less than .010, (not something that can be checked with a snap guage and a V. caliper)
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 02-01-2010, 05:47 AM
Gertvr's Avatar
Mike, thanks for the explanation, I will call you to discuss further .
Cheers
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 02-01-2010, 07:54 AM
i like a light finger push to move the pin in the bushing. not a hard push, and not so loose that it falls out with it's own weight.
206 637 4071
Old 02-01-2010, 08:29 AM
Gertvr's Avatar
John,
This is where its at for the small end bush, the pin fit to the piston is a little tighter and requires more effort to move the pin in the bore.
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 02-01-2010, 10:06 AM
a semi hard push to move the pin into the piston is good. nice when you can still do it with your thumb or just light taps on your pin install tool. i like a slightly firm pin bushing fit in the rod when new, because the microscopic roughness from the honing job gets smoothed out after running and clearances increase a tad bit.
206 637 4071
Old 02-01-2010, 10:16 AM
Gertvr's Avatar
Thanks for all the inputs,
As future data point for someone using the same combination (Wossner pistons / Pauter rods), both companies tech reps indicated between 0.0006 - 0.0008" for both piston and small-end bore to wrist pin clearance.
I will go middle of the road .0007" on both.
Cheers
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 02-02-2010, 11:08 AM
