another deck height question
I'm reassembling a 3.3 turbo motor. No machining was done at all.
I am rebuilding using the same used pistons and cylinders (the case was not split). When I disassembled the motor, I had only one 0.25mm copper base gasket. I checked the deck height now as I have started the rebuild and can either get 1.15mm or 1.4mm with either one or two 0.25mm shims. The only change I am making to my engine is the SC cams which from my understanding have higher lift. Thoughts? |
Mark,
Were your heads resurfaced (I hope they were)? Use one base (.25mm) gasket for your 1.15mm deck height: you will not have any piston-to-valve clearance issues. |
Yes, they were resurfaced.
| All times are GMT -8. The time now is 03:33 PM. |
