-   -   Cylinder Head Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/524852-cylinder-head-question.html)
mickday 02-04-2010 10:32 AM
Hi,
In the Rebuild book it mentions on page 153 quote "The Heads should come back from the machine shop completely assembled and ready to install. If you wish to disassemble the heads and check the tolerances and spring heights, see the instructions at this book’s official web site: http://www.101projects.com"
I cannot find these instuctions anywhere?
Can anyone help?
Regards
Mick
snbush67 02-09-2010 10:55 PM
I couldn't find the article either :
101 Projects for your Porsche 911 & How to Rebuild and Modify Your Porsche 911 Engine: More Articles
mickday 02-16-2010 06:24 AM
Anyone help with this query?
tom1394racing 02-16-2010 07:30 AM
You can buy a valve spring compressor from your local NAPA parts store. This will allow you to compress the valves and remove the valve keepers. You can then remove the valves and springs and inspect them to the specs in the rebuild book.
After inspection you can reassemble in the reverse order.
HelmetHead 02-16-2010 01:40 PM
I think your looking for this page with the additional photos that used to ship on a CD with the book..
How to Rebuild and Modify your Porsche 911 Engine: Sample Projects
