Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Dude, that sucks, Sorry to hear that. Myself, I have to service the axles on my RS before it goes on the road. I'm going to drill the bolts and safety wire them just in case.
I had the same thing happen to my 914 just after I got the motor back into the car. I was lucky as I heard an odd noise as I pulled into the parking lot @ home. The last bolt backed out just as I was 10ft from my stall.
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
90 Miata, suspension goodies and 15x9" wheels on all 4 corners w/Hankook R-S3 rubber make it stick like velcro
1969 Camaro "The new project"
Old 03-23-2010, 12:07 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #81 (permalink)
Max Sluiter
Flieger's Avatar
Location: San Luis Obispo or Thousand Oaks , California
I am sure you are aware of this but, make sure no CV joint grease gets on the threads.
911S
lightened, 2.7RS spec MFI engine, IROC RS look, suspension mods
http://www.flickr.com/photos/max_911_fahrer/
Old 03-23-2010, 12:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #82 (permalink)
Shane
snbush67's Avatar
Thanks, I torqed them to 32 foot lbs. and have ordered the stage 8 bolts.
Shane -- 78SC Big Port 3.2 SS, 46 PMO Carbs, M&K 2/2, RARLYL8 Headers, DRC GT2-108 Cams, MSD, Clewett Wires, J&E 98mm (Disclaimer-I am a novice and pretend to know just enough to be dangerous (I have the scars to prove it). By reading my post you accept that I am not responsible for any bodily harm, mental anguish, material and/or monetary losses that may result from anything you choose to do based upon my shared experiences.)
Old 03-26-2010, 01:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #83 (permalink)
hello,
i have a similar motor, also with 46 pmo carbs - just breaking in
what sizes of ventures, airs, jets and emu tubes did you use at the moment?
thanks
on the road...
Old 03-26-2010, 01:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #84 (permalink)
Shane
snbush67's Avatar
Arrow High Performance 3.2 Liter Short Stroke - By Shane Bush
Here is my build-
1 Jan 2010 - 17 March 2010
3.0 Liter SC Case
Early SC Heads: Large Port 38mm
Stock Crank : Stroke Leangth 2.772"
Stock Rods
3.2 95mm Cylinders : Bored to 98mm (3.8582")from EBS
98mm J&E Pistons/pins/clips : Compression Ratio 9.5:1: Dome Volume 35.2cc
Gotze Rings : Top, 2nd and Oil : End gaps: .0015mm
GT2-108 Dougherty Racing Cams : Timing set at 3.2mm
High Lift Racing Springs and Retainers : Spring Height : 39.5mm, 110 lbs
PMO Carburetors and Manifolds : 46mm
Venturies: 38
Main: 160
Air: 190
Idle: 55
Idle Air: 130
Emul: F11
Thick flange SSI's
M&K Generation V, 2 in 2 out Muffler
Clewett Racing Wires
MSD 6AL Ignition
MSD Blaster Coil
Chain Housings gasket surface milled .1mm (modified for 3.2 Gaskets)
Rocker Arms resurfaced and reconditioned by C. Garret
Rocker Shafts reconditioned by C. Garret
New Valve stem seals
New Valves : 2E, 3I and 5I
New Oil Return Tubes and gaskets
New 3.2 Chain Housing Gaskets
New Chain Ramps
New Cam Seals and Gaskets
New Exhaust Manifold Gaskets
New Intake Manifold Gaskets
Used 3.2 Cam Bolts and Washers
New 3.2 Pressure Fed Tensioners
Used 3.2 Idler Arms and Sprockets
Shane
Old 03-26-2010, 02:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #85 (permalink)
Thank you!
here is a picture of my version, a few hours before the first run!
thanks
on the road...
Old 03-27-2010, 12:08 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #86 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Dang! that's clean!
Tom
Old 03-27-2010, 12:19 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #87 (permalink)
Carrerax's Avatar
Tom, can you post a few pictures of your CD/MSD boxes mounted and also a close up of your coil mounts? Im also building a 3.2ss with twin plug and 46 PMO's and looking at different ways to mount things.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
Old 03-27-2010, 03:55 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #88 (permalink)
Shane,
My build ended up being very similar except I left the bore at 95mm. GE 60 cams, 46 Webers, 10.5 : 1 JE pistons with various bits and pieces from Rennwerks and Supertec. Looks like Tom Sch has the Rennwerks twin plug dizzy as do I; nice piece.
My stock rods got the once over by Rennwerks and received Raceware bolts. Although I have not driven the car yet, I have run the motor in and let's just say it likes to rev; like a light switch. I can't wait to drive it.
Lindy
Old 03-27-2010, 06:04 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #89 (permalink)
hello,
i hope it's o.k. for shane in his tread...
thanks
on the road...
Old 03-27-2010, 09:54 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #90 (permalink)
Shane
snbush67's Avatar
Thumbs up
Originally Posted by Tom Sch View Post
hello,
thanks
Absolutely, Tom that is great, impressive!
Can you share your source on the fiberglass parts?
Old 03-27-2010, 01:58 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #91 (permalink)
Shane, thanks for coming by today and giving me a ride in your beast! That motor absolutely rips!! When I finished up @ the shop today I took my Carrera home and punched it a couple times, and by comparison, yours is more responsive.
Not to mention the incredible music it produces when the PMO's are fully open and the dual exit muffler barks..................Just awe-inspiring
Tommy
Tom
Old 03-27-2010, 09:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #92 (permalink)
i have ordered the fiberglass parts direct by my motor builder!
thanks
on the road...
Old 03-28-2010, 01:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #93 (permalink)
Walt Fricke's Avatar
Shane
How can the redoubtable Craig Garret, or anyone else, "recondition" rocker shafts?
I suppose they could be polished, but mine (I have a large bag full of used ones) are either somewhat scored (despite reinstallation with the "good" part toward the engine), or actually worn to where I can feel the edge of where the bushing ran.
Will polishing remove the normal scoring/wear indications?
Old 03-28-2010, 02:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #94 (permalink)
Shane
snbush67's Avatar
Porsche Crest
Walt,
I sent them to him with my rockers not expecting anything, they were and still are slightly scored but well within spec.
He simply polished them and mitigated the scored surface.
I really had to work to find the original wear marks and did install using the "good" side.
I used the term "reconditioned" because it sounds more technical than saying "Budget Polish".
Shane
Old 03-28-2010, 04:13 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #95 (permalink)
abit off center
cgarr's Avatar
The shafts most times look worst than they actually are. Most measure out at .7082 and new is .7086 Here is one that was measured then just polished. With the new bushings the shafts should really never again scar up like with the bronze bushings.
______________________
Craig
G2Performanceshop.com
Twinplug and head work, casesavers, rockers arms, etc.
Old 03-28-2010, 04:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #96 (permalink)
camgrinder's Avatar
thanks
Tom, what camshafts did Oliver put in that beautiful engine?
John Dougherty
Old 03-30-2010, 12:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #97 (permalink)
Shane
snbush67's Avatar
Thumbs up
Originally Posted by BURN-BROS View Post
Good choice. Enjoy your short stroke!
Aaron,
You were dead on about the green and purple wire, all is good now.
Thanks, Shane
Old 03-30-2010, 08:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #98 (permalink)
that is one of olivers secrets
sorry - but i dont know it and oliver reveals nothing
on the road...
Old 03-31-2010, 03:32 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #99 (permalink)
BURN-BROS's Avatar
Aaron,
Thanks, Shane
Your welcome!
Aaron.
Burnham Performance
1071 Avenida Acaso suite D Camarillo, Ca.
805-240-6931
Old 03-31-2010, 07:17 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #100 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
