deck height puzzler.
i had my mag case machined for my rebuild.
ollies provided 1mm cylinder gaskets. also had my heads done. when i measure deck height i get no deformation of the 3 mm solder bits. i think the solder is moving away from the edge of the cylinder on compression. how can i get an accurate measurement? btw its a 72 e |
Try some clay in there then you can measure it with the back side of a caliper.
thanks craig that worked nicely.
| All times are GMT -8. The time now is 08:51 PM. |
