Recommendation for machine shop in San Diego
Can any of the San Diego Pelicans recommend a machine shop for a 911 3.2 engine?
I need new valve guides, a valve grind, checking clearances on Ps & Cs, cylinder hone and replacement of head studs. Thanks Seth |
Scott's Porsche
National City Ca. Give them a Call. |
Motor Works in national city is a machine shop that can get your stuff done quickly and has pretty reasonable prices. Many local independent porsche shops use these guys.
Motor Works If you want some advice as well I would take the work up to Supertec in fallbrook. Its a bit of a drive but if you have any questions about your motor build you can bounce them off Henry when you drop the stuff off. |
| All times are GMT -8. The time now is 09:37 PM. |
