Intermediate shaft gears installation?
Using the hot & cold method of installing the two new timing chain gears onto the shaft. What temp should I heat the gears to? Oven or Oil in a pan method?
Thanks David |
I did oil in the pan...worked like a charm.
Hot Gear http://asbury.smugmug.com/By-Land/Po...03_edB9F-L.jpg Frozen IMS http://asbury.smugmug.com/By-Land/Po...61_Vieym-L.jpg All done http://asbury.smugmug.com/By-Land/Po...45_TBdmN-L.jpg |
I use my outdoor gas grill set at 500 deg F.
Keeps me out of trouble with the wife. |
| All times are GMT -8. The time now is 03:17 AM. |
