Now in 993 land ...
aigel's Avatar
Resealing 3.6 993 - what gaskets / seals to change
All,
My engine is out for transmission work and while it is all nicely accessible I'd like to reseal it. I have some minor leaks from the chain / tensioner area and valve covers. So my plan is to at least do a valve cover and chain cover gasket kit. I am also doing the RMS.
What other gaskets are prone to leaking and may be part of my "sweaty" underside of the engine? I did a reseal on my SC and there you had cam end plate gaskets and oil thermostat as well as oil pressure switch. Anything like that on the 993 3.6 that is good preventative maintenance?
Thanks!
George
81 SC (sold)
Old 03-16-2011, 03:24 PM
