-   -   Problem seperating cam towers from heads (http://forums.pelicanparts.com/911-engine-rebuilding-forum/527907-problem-seperating-cam-towers-heads.html)
Robert Shafer 02-23-2010 12:32 PM
Have removed cam towers and heads to do valve work and can't get heads seperated from cam towers. When I originally assembled them I used either Threebond 1194 or 1211 can't remember which
304065 02-23-2010 01:42 PM
How many nuts did you remove?
tom1394racing 02-23-2010 01:50 PM
Here's my process that works every time:
1. Remove rockers and cams from towers
2. Remove all cam tower retaining bolts
3. Place the cam tower/head assembly on your workbench with two 6" sections of 2X4' under each outboard head so that the middle head is elevated above the
workbench
4. Thread two of the Allen head cam tower retaining nuts halfway onto the two diagonal outside head studs of the middle head. This will protect the threads on the studs for step 5
5. With a punch inserted into the Allen head nut, alternately tap the two diagonal studs until the head starts to separate.
6. Remove the middle head and place all four 2X4 pieces under the middle section of the cam tower and repeat steps 4 and 5 on each of the outboard heads
Robert Shafer 02-25-2010 12:19 PM
John C
Hopefully all of them, thanks for suggestion
Tom
Used your method and it worked, thanks really appreciate it.
Bob Shafer
