-   -   Best cam? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/528898-best-cam.html)
kyhunting 03-01-2010 02:10 PM
Best cam?
What is the best cam for this engine? (Currently using GE-60) Is there a better cam for this configuration? I have to stay at least at 6800 RPMs to make good power. What is everyone else using?
Vintage race car:
914-6
2.7
S-Heads (Twin Plug)
11.5:1 Pistons
Headers
Weber 40's (160 Mains, 36mm Choke Tubes, F3 E-tubes, 170 Airs)
Race Gas
Trans with short gears
Dry Sump
camgrinder 03-01-2010 08:32 PM
If I understand your correctly, you are having trouble making power below 6800 rpm?
The GE60 cam should have a 4800 rpm and up powerband in this engine. I would check the camshaft timing and make sure they are set at 5.0mm +/- .2mm. A late setting (4.0mm or lower) can move the powerband up and kill torque.
You might also swap out to a 34mm venturi's in the carbs.
Have you run the car on a chassis dyno?
