-   -   What is the modern equivalent to a 906 cam? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/528951-what-modern-equivalent-906-cam.html)
obrut 03-01-2010 06:29 PM
The 906 cam is often described as an 'old fashioned' profile. Not that suprising given it was developed 40 or so years ago.
What would be the closest 'modern' (whatever that means) cam design to a 906 profile? Application is a 2.0 litre engine.
Eagledriver 03-01-2010 07:19 PM
The 906 was a very high RPM cam profile. It was also designed to keep valve accelerations to a level that was within valve spring capability of the day. A modern cam like the GE-100 would be for a similar RPM range but is superior. It is designed around racing valve springs and titanium retainers.
-Andy
camgrinder 03-01-2010 08:19 PM
A good replacement for the 906 is a DC60 profile. More torque and HP, and will still pull past 7600 rpm in a 2.0 litre. If you want 8k plus potential, go with a DC80. The DC100 (similar to the GE100) would be closer to the 3.0 RSR cam. I cant remember the last time I made the DC100 for a 2.8l or smaller engine.
obrut 03-01-2010 09:00 PM
Thanks guys.
John, you have PM.
Henry Schmidt 03-01-2010 09:44 PM
I would have tought that a DC 100 was closer to a Shrick cam from the old 2.5 IMSA days.
Just to refresh your memory, you made me a few sets of what we called a DC90 for a couple of 2.5 engines I built 2 or so years ago.
obrut 03-02-2010 03:12 AM
Thanks guys.
A buddy is using DC44 on 102 degree lobes in his 2.3. How would these compare?
camgrinder 03-02-2010 08:34 AM
That "IMSA" cam has even more duration than the 100 cams do.
It would be interesting to see a DC90 on a 98 lobe center in a 2.0 litre. With lots of compression.
camgrinder 03-02-2010 08:39 AM
Originally Posted by obrut (Post 5213085)
Thanks guys.
The DC44 cam is in between the DC40 and the DC60. It has slightly less duration on the intake, but more lift on both sides vs. the DC60.
Henry Schmidt 03-02-2010 01:32 PM
I wasn't talking/ referring to the Elgin IMSA cam That was a monster.
I was referring to the Shrick cam which I believe was the basis for the GE100.
You're the cam guy and I wouldn't doubt you for a second just something floating around in my cranium.
camgrinder 03-02-2010 03:04 PM
Got ya. I have a Schrick that checked out 272/260 @ .050" with .520"/.500" lift on a 98 lobe center.
gestalt1 03-02-2010 05:21 PM
i find it interesting that many think of the 906 as the race cam from porsche's past. what about the rsr sprint? it seems rather close to the ge60, wouldn't the sprint be the modern replacement for the 906? how would a sprint work on a small bore race engine?
kenikh 03-02-2010 07:44 PM
Thanks guys.
Cameron's cams were designed by John, for me, with the design criteria of making more torque, sooner than an 'S' cam, but with near 8000 RPM potential. Those cams make peak HP at 7800 RPM and are one of the best cams you can build for a small motor. If going to 8K, the ramps speeds require a lightened valve train.
I describe them as "hitting low like an 'E', then exploding high like a 906". While overstating it a bit, they were designed specifically to feel very E-like low in the RPM range and very 906-like high up. The specific target for the cams was just short of 100HP/L on CNC ported heads and taper bored MFI at shy 8K RPM.
My project changed directions and Cam was the beneficiary of my flighty way. :) That reminds me, I need to email him.
kenikh 03-02-2010 07:48 PM
FWIW, the Sprint cam is more fun than a barrel of monkeys on a 2.8 short stroke. Makes this motor feel like a 2.2S on McGwire quality steroids, then just keeps pulling past 8K like no 'S' cammed car would dream. Best damned NA motor I have ever driven.
kenikh 03-02-2010 07:49 PM
What's "lots"? Race gas only "lots" or pump gas "lots"? Twin plugs are assumed.
Walt Fricke 03-03-2010 12:58 PM
Kenik - you wrote:
"FWIW, the Sprint cam is more fun than a barrel of monkeys on a 2.8 short stroke. Makes this motor feel like a 2.2S on McGwire quality steroids, then just keeps pulling past 8K like no 'S' cammed car would dream. Best damned NA motor I have ever driven."
Is this the "RSR Sprint" cam?
The 2.8 SS I am slowly assembling (just got the heads back from twin plugging and valve guiding) will need a cam. I am hoping for ~12 CR, though with the valves I am using (51.5/42.5) I am going to have to recut the J&Es, which were designed for stock 3.2 sizes, and that will add volume). My plan is to shift at 8,000 rpm (for a little more bearing, spring, and valve longevity), which is apt to mean a HP peak of about 7,500 or so, and a torque curve to attain that (I'm going off of the shape of my current 2.7 race motor torque curve and transmission gearing, where 7,600 is the optimum shift point for a torque peak about 6,000 and a HP peak about 7,100).
My take is that moving the torque curve too far up means shifting at optimum will be higher than I want. And short shifting is apt to mean giving up something on the low end, given that you can't expect a torque curve to be flat from 3,000 rpm through 6,600 plus rpm, and with the cam you are sort of moving the curve around.
So the RSR sprint might be a bit too much. Do you have a torque curve for this in the 2.8 SS application you could share?
Walt
kenikh 03-03-2010 01:52 PM
Walt, you havr two major design concerns to accomodate in pursuit of your goal big (meaning heavy) valves and very high CR. The Sprint cam has nice, gradual ramps that will accomodate these heavy valves at high RPM, as well as lots of overlap to accomodate your high static CR, by lowering dynamic compression, especially at lower rpm.
Anything "less" in terms of overlap would gain low end torque, at the cost of running into major detonation problems due to elevated dynamic CR. Also with a more "modern" cam (with faster lobe ramps), you'd need at a minimum, titanium retainer and even possibly titanium valves to get a reliable 8K.
The Sprint cam in a 2.8SS makes more power low than you could imagine. When I said a 2.2S on steroids, I meant in terms of character. This motor makes way, way more power everywhere, from idle up than a 2.2S. It is a fantastic combo and is why Henry likes this cam so much in the 2.8SS. Also, the 2.8SS has gobs of displacement to overcome low RPM pumping losses from overlap that smaller motors just can't.
It is definitely NOT too much cam.
I am sure Henry has posted some dyno sheets on his Sprint cammed 2.8SS...see if you can find them in the engine rebuilding forum.
gestalt1 03-03-2010 02:17 PM
i brought up the rsr sprint because it seems to have less overlap than a 906, 101 vs 96 lobe center. should i assume that the duration is so long on a rsr that even though the lobe center is wider there is still a lot of overlap? i am thinking that the wider lobe center would help at lower rpms. do you think stock springs/valves and retainers would be ok with an rsr cam up to 7600 rpm?
kenikh 03-03-2010 02:48 PM
I have run an RSR cam on a 2.8SS to 8300 RPM with relative frequency. No issues, especially with Ti retainers.
Henry Schmidt 03-03-2010 03:55 PM
The magic to the RSR sprint cam is that it will function relatively well at all rpm ranges including idle with as little as 9.5:1 compression. This means you can run a twin plug engine to 8500rpm on street gas. This engine does just that.
Look to future issues of Excellence magazine for an article on the Red Sled
http://forums.pelicanparts.com/uploa...1267660264.jpg
kenikh 03-03-2010 03:57 PM
I cannot wait!
Jeff Alton 03-03-2010 07:06 PM
What sort of power and torque are you seeing out of 2.8 with the sprint cam, assuming carbs or MFI and not slides?
Cheers
Walt Fricke 03-03-2010 07:36 PM
Kenikh
Actually, the 8mm stem valves I have weigh less than stock 3.2s do. And intakes only 6g more than the stock 2.7s I have been running. Ti retainers, of course.
Sounds like I should add the RSR Sprint grind to my list of candidates, along with the GE100, the Webbcam 171/149, and something from Camgrinder.
As to dyno sheets on Henry's 2.8SS, I think many have asked, but none have answered. Perhaps all will be revealed in Excellence. You can't fault an engine builder for holding some of his information back.
Walt
Henry Schmidt 03-04-2010 08:44 AM
The 2.8 Slider was built over seven years ago and I no longer have a sheet on it.
Sorry guys
kenikh 03-04-2010 09:32 AM
Originally Posted by Walt Fricke (Post 5216637)
Kenikh
Walt
I'd recommend doing what I do with every engine build: call John Dougherty.
When I need a cam, I tell him:
  • My bore and stroke
  • My static compression
  • Type of heads/valves/retainers I prefer to use
  • My port specs
  • My induction type
  • Where in the powerband I want to make peak power
He'll then give you a laundry list of stock and custom grind cams. He will work with you to tweak lift, ramp speed, lobe spacing and durations to create a cam perfectly tuned to the details you give him.
For example, when I was building a 2.3L ST inspired motor, told him I was OK with using Ti retainers, wanted 'E' like torque and 906 top end power...a tall order, given I wanted 100 HP/L potential around 8000 RPM with grunt. I mentioned '69S heads, CNC port work @ 39mm I/E and asked him to build me a dream camshaft.
He custom ground me a set of DC44s on 102 lobe centers...this was before they became a regularly stocked item on his site :). These cams ended up being EXACTLY what was specced: Velvety low-end torque, with the engine going completely bonkers from 4500 RPM to 8000 RPM redline (peak HP falloff ended up being exactly at his estimated 7800 RPM).
The 2.25L motor made...drum roll...225 RWHP on its first dyno run, with a torque band that an 'E' motor of similar displacement would be envious of and top end power that is nearly the equal of a 906.
Call John (aka "The Magician") :cool:
kenikh 03-04-2010 09:42 AM
Cheers
One car I know of got 249 RWHP on 46 PMOs, but a restrictive muffler and exhaust was a limiting factor, as was jetting and timing when the dyno run was completed. The car runs stronger now, but has not had a dyno run since the latest tuning.
Today, it feels like an honest 275 RWHP, which is in line with Henry's quoted 300HP for the Red Sled, given the other car's induction and exhaust disadvantages:
Wild Porsche Engine
MaRu 12-16-2013 01:10 PM
GE 80 vs 906
Old thread, I know. -but maybe someone can share his opinion with me on the best cams for my engine.
Ok, the choice is not to big as I only have two cams to choose from . GE 80 and 906.
My engine is a 3,0 with 10,3 CR, 41 mm inlet port, standart SC Valve size, headers, open exhaust, ti-retainers, Eibach springs and MFI with 50 mm butterflies. I use the car for tarmac rallyes...
Many thanks, Malte
MaRu 12-16-2013 01:12 PM
forgot the twin plug and 102 octain pump gas...
camgrinder 12-16-2013 01:15 PM
Many thanks, Malte
the 80's are better than the 906's.
MaRu 12-16-2013 01:21 PM
Thank you very much for your fast answer!!!
MaRu 12-17-2013 03:06 PM
MFI Adapter
I have another question...
Is the part I need to connect the mfi drive with the camshaft an original part? Difficult for me to explain, but attached is a pictore of how my camshaft end looks like. And I think I need a kind of adapter for this???
Thanks, Maltehttp://forums.pelicanparts.com/uploa...1387321513.jpg
camgrinder 12-17-2013 03:41 PM
Yes you will need an extension out the back of the left side cam. I make them, but they are rough on the outside dimension. I bolt them on and grind them concentric to the rear bearing journal. (less likely to leak)
http://drcamshafts.com/drive.jpg
MaRu 12-18-2013 06:40 AM
Hello John,
thanks again! I just saw by the name that you built the cams I bought (not directly from you).
My problem is not only that the cams are already installed but also that I am in germany.
Is there a chance that you make it without the cam and it will not leak oil, or is it worthless?
camgrinder 12-18-2013 07:54 AM
Originally Posted by MaRu (Post 7811845)
Hello John,
Those must be 6 or 7 years old? I cant get that type of blank cam anymore. The ones I have now come with the mfi drive. There is a chance I have a used cam here with the same back side. If I do it might be possible to make the drive, unbolt it and bolt it to yours.
MaRu 12-18-2013 08:53 AM
On the parcel is a sticker that you sent it to a guy called Jay Kjoller. There is no date, -I bought them here on pelican some month ago...
It would be great if you can check if you have a used with the same end which you can use for making the gear- otherwise it looks like I am having a problem.
camgrinder 12-18-2013 09:34 AM
I have a sample cam to work with. If you can, please measure the depth from the end of the cam to the inside surface where the drive will bolt to. The one I have here is .240" deep.
MaRu 12-18-2013 10:30 AM
Great! I have 0,250
MaRu 12-19-2013 03:01 AM
I just sent you an email with some questions
camgrinder 12-19-2013 08:03 AM
Got it and responded.
