cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
does octane booster work
I seem to be on the edge of detonation. In addition to the other steps I am taking (mixture, colder plugs, working pistons squirter's, etc), would adding a can of octane booster help. Snake oil or worth it?
Thanks,
Chris
73 911 E
Old 07-09-2013, 12:36 PM
definitely helps
In my experience one of those small bottles added to a tank bumps the octane by approx 2 points. With 90 octane my 5.9 Durango would detonate like mad but no issues with 92, or one bottle added. I always carried a few of those bottles when going to remote areas where only 90 octane was available
80SC (ex California)
Old 07-09-2013, 12:53 PM
Straight shooter
Lapkritis's Avatar
Have you considered taking a little ignition timing or compression out of it? Great time to do it while you have the pistons and cylinders off.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-09-2013, 02:30 PM
