Super Moderator
cstreit's Avatar
Fresh engine - What to expect in oil?
Gang,
Just completed my 2010 race engine...
I went through a spun rod bearing last year. Everything was taken apart and cleaned laboriously before assembly including replacing/cleaning the front oil cooler circuit.
I imagine there will be some amount of metal in the oil during the engine breakin process. I'm using a different assembly lube (Joe Gibbs Brand) this time that doesn't contain Moly (specifically to track what IS in the oil) so previously I had always seen that there was a sheen from the moly additive. The moly obviously made it impossible to distinguish any metal from the engine.
Now that I can see, how much stuff should I expect to see in the oil on this engine from "normal" break-in. (Just a little sheen or sparkle, some small bits, etc..) Just don't want to have a freakout over nothing.
thanks.
Chris
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-22-2010, 06:37 AM
RichHawk's Avatar
My 3.2 L first 20 min break in didn't have nearly as much sparkle or flake in it as Wayne led me to believe in his book.
Yes, there was a bit of greyish metalic reflectiveness to the oil, but no individual discernible sparkly pieces. the color I attribute mostly to the assembly lube.
my 50 mile break in oil change is going to happen tomorrow. we'll see what hat yields.
Richard
Old 03-22-2010, 07:55 PM
efhughes3's Avatar
Aww heck, just change it at twilight. You won't be able to see much bad stuff then.
I didn't have tons of stuff in my oil after my build. Some swirls of very tiny bright bits IIRC.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 03-22-2010, 08:25 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
The idea that bits of metal may be left over and then harm your engine are very real - happens all the time in many componants. In fact, this is one reason why you get the 'Bath Tub" curve when defining failure:
Michael D. Holloway
https://5thorderindustry.com/
Old 03-22-2010, 09:25 PM
