-   -   poping from left side chain case !! what the heck (http://forums.pelicanparts.com/911-engine-rebuilding-forum/532853-poping-left-side-chain-case-what-heck.html)
carrera turbo 03-23-2010 10:10 PM
just got finished resealing a 2.7 for a friend of mine and set up the cam timing using the mechanical adjusters to set timing, not my first motor build but something is not right. after setting the cam timing i spun the motor around double and triple checking my timing before installing the pressure fed tensioners, after this i assembled the rest of the motor and and before i buttoned up the valve covers i double checked the valve adjust, while turning the motor over slowly i now get a distinct click from the left timing cover area. this only happens when turning the motor over very slowly. if i turn it with any speed with a 3/8 ratchet clockwise of course it makes no noise and is smooth. but if i turn it very slowly i get a random pop or click from the left side only. the gears are all in line the chains and sprockets are the ones that where in there and on the same side turning the same direction no change was done there. cams are torqued and cam thrust plates and washers are all in there place. so im gonna tear that side back apart and see whats going on in there. i was thinking maybe it was the tensioners causing it as it was not popping with the manual adjustable tensioners in there, i did have them a bit tighter than the pressure fed one are holding it now with no oil to them. the spacer is installed with the tensioner pulley and was free to float just a bit so im thinking maybe the idler wheel is making the noise as there is not much else that is free to move. anyways just thought maybe someone has run into this.
cheers ed
lindy 911 03-24-2010 06:24 AM
The same thing happened to me and it was the idler arm not aligning with the chain as it floats. It will line up on its own but pulling the cover just to be sure never hurts.
Lindy
cgarr 03-24-2010 06:55 AM
Are the cam gears on correct? Left side dish out, right side dish in?
carrera turbo 03-24-2010 07:51 AM
Lindy
Thanks for the reply, this is what im thinking as well but just want to be sure before i put it in the car. what did you do if anything to remedy the problem? i will have it apart this evening after about 6.p.m. and will see what we have going on in there, my luck by the time i get it apart to inspect it it will be silent and have fixed it self:confused:. but it will be looked at none the less as i just wouldn't sleep if i didn't look:(
hello cgar
yes the gears are correctly installed and even on the same cams and side they started on. the idler float has to be it, as even with the spacers that where in there there is room for the idler slide on its shaft just a bit side to side. i checked the idlers for bushing "bearing" wear before installation and they spun smooth with no defects i could see.
i was thinking maybe because the chains are dry no oil on them that idler gear is creeping up the side of the chain just a bit with the metal to metal contact. i know this is all speculation till i get it apart.
thanks for the replies any in site always helps
cheers ed
Flat6pac 03-24-2010 11:44 AM
I would be looking at the math of the chain alignment to intermediate shaft.
Bruce
carrera turbo 03-24-2010 10:08 PM
Bruce
i will double check it again and see what i come up with,i have waynes book and double checked myself but hey we all make mistakes.
cheers ed
john walker's workshop 03-25-2010 01:48 PM
i would suspect it's just the normal lumping you get as the rockers slide off the cam lobes, acting on a not quite pumped up hydraulic tensioner. maybe. is the chain all the way on the intermediate sprocket, not 1/2 way on?
efhughes3 03-25-2010 07:56 PM
There probably isn't much lube on the sprocket either at this time to shed the chain at slow speeds which couples with Johns diagnosis on the tensioner.
carrera turbo 03-25-2010 09:04 PM
hey john
i think your probably dead on as far as the no pressure to the tensioner. it is on the chain and in both groves or sections as needed. thanks for the response and i think ill pull the temp sensor and squirt a bit of motor oil in there and see what difference it makes before i tear it apart. ive been busy taking my coast gaurd 100ton. masters test the last few weeks so havent had much free time.
cheers ed
you gave me the idea to squirt a bit of oil on the chain and see if it changes.
cheers ed
