-   -   Type of sealant to use? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/534186-type-sealant-use.html)
Paul LeFevre 03-31-2010 05:35 AM
what type of sealant would be used to seal a brass screw-in fuel pressure gauge into an aluminum fuel rail? My friend is having problems with it leaking. Thanks in advance. This is not a porsche project, but know there are very smart guys here.
abisel 03-31-2010 10:15 AM
Are the threads on the gauge pipe threads? If so, use the teflon tape you can get a plumbing supply. Tighten the gauge snuggly, do not overtighten.
If the threads are are a machine thread, try using a copper crush washer.
MBruns 03-31-2010 08:24 PM
sealant
Loctite 574 works well as a thread sealer
Mike Bruns
