-   -   SC cams in a 73.5? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/534814-sc-cams-73-5-a.html)
Sigurd 04-03-2010 02:33 PM
SC cams in a 73.5?
I have a set of 3 bearing SC grind cams on the shelf. How would they perform in a 2.4 CSI? Is it worth doing the change?
Steve@Rennsport 04-03-2010 02:42 PM
Hi Sigurd,
Those SC cams will build you a little more top end power in a 2.4T, at the expense of a little bottom end torque. I would likely not do this unless I installed closer ratio gearing.
Sigurd 04-03-2010 02:55 PM
Steve,
thanks, you just saved me some work!
