loose nut behind wheel
cudabnu's Avatar
California Smog -vs- JE Pistons
Looking to see if anyone using JE pistons in their 3.0 has had any problems passing smog. Before I pull trigger and get new P&C's I want to make sure the smog gods will smile once more upon me! Building a 80 3.0 possible going to a
3.2ss
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 04-16-2010, 09:00 AM
I'm here to cause trouble
jimbauman's Avatar
FWIW, just upgraded a friend's 3.2 to 3.4 with JEs and Nickies - no problem at all with smog....
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 04-19-2010, 01:48 PM
cudabnu's Avatar
Did he upgrade the cams? That's the next thing to look into...
Old 04-19-2010, 02:59 PM
jimbauman's Avatar
Yes, 964 cams from Camgrinder....
Jim
Old 04-19-2010, 03:02 PM
3 restos WIP = psycho
kenikh's Avatar
I don't see the CARB guys tearing down your motor to check what brand of pistons you run...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-20-2010, 02:10 PM
cudabnu's Avatar
Correct, but if the dome design isn't as efficient as the stock design, then they will "see" it on the sniffer
Old 04-20-2010, 03:58 PM
kenikh's Avatar
I'd be curious to see if that is possible.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-20-2010, 04:04 PM
I thought JE optioned a CIS dome too. Can anyone confirm that? EBS maybe?
I was curious if they offered the CIS dome on their new piston style casting.
'82 911
previous:
'86 951
'72 914
Old 04-20-2010, 05:09 PM
boxermania's Avatar
Not living in California, I need to ask:
Are there any emission exemptions for cars older than 25 years or for that matter older than a specific year?
Al Morales
77 911 S (930 steel conversion)
88 BMW M3
79 Honda CBX
Old 04-21-2010, 09:50 AM
jimbauman's Avatar
1974 and earlier are exempt. They eliminated the rolling exemption years ago.... :-(
Old 04-21-2010, 09:51 AM
It's actually 75 and earlier.
Old 04-21-2010, 02:52 PM
efhughes3's Avatar
I believe there is a classic car exemption still available. Somewhat restrictive on when you can drive the car.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-21-2010, 06:18 PM
89turbocabmike's Avatar
Cam specs would be more of a factor in passing smog than piston design I should think. Smog specs for that 30 yr old engine are going to be fairly lenient and a fresh engine should be much cleaner than a friend's stock 3.0 with 200k that just past smog.
Old 04-22-2010, 10:47 AM
cudabnu's Avatar
I took my parts to Aaron at Rennwerks with the 3.2SS in mind, and just send the cams to Camgrinder to be ground to the 964 profile
Once I build up my cash reserves again, then I'll get the Supertech head studs and find some used 3.2 cylinders to send out for the 98mm bore and re-plate for the JE pistons.
If it doesn't pass smog, I always have family in Oregon!
Old 04-22-2010, 10:52 AM
cudabnu's Avatar
Old 04-22-2010, 10:54 AM
efhughes3's Avatar
No leniency in Calif for smog.
Old 04-22-2010, 12:06 PM
