Valve stem acceptable wear
Hey guys,
I am in the process of purchasing an 89 coupe. However, on leakdown, cylinder #5 had 14% loss. The rest were in the 3-6% range, and three spark plugs were oily. Oh yeah and smoky start up of course. So I agreed to buy the car based on replacement of the valve guides and a close inspection of #5 cylinder. This was a week ago. So now, the heads have been removed and new guides installed. Machine shop says valves are fine, so they were going to re-use all the valves. Just to make sure the shop is doing good, what is the acceptable range of wear for the valve stems? Thanks in advance, Alfonso. |
1 thou
Super Moderator
I'd put in new valves.. They aren't that expensive...
I kept the intake valves, but I replaced the exhaust valves on my '86 3.2.
Ed 1973.5 T |
If they are in factory spec there is no reason to replace them, the new ones are only in factory spec too.
Bruce |
FWIW,.....I'll reuse intake valves as long as they are within spec, but I always replace exhaust valves if they have gone more than 50K.
They really live a hard life and I've seen them fail at high mileage despite stem wear. Its simply not worth the risk, IMHO.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Hey guys, thanks for the responses.
My question specifically is what is the spec for acceptable wear. Porshaah says 1 mil, but I think that's a little high. I would expect something like .5 mil? Steve@Rennsport, thanks for the recommendation on replacing the exhaust valves.
From the factory workshop manual (Ref No 4805.20 1965 pg E73-E75) for the 2.0
I beleive these are unchanged through to the 1989 3.2 - others please chime in if this is not the case...... Inlet valve stem = 8.97 (-0.012) mm Clearance = 0.030-0.057mm Exhaust valve stem = 8.95 (-0.012) mm Clearance = 0.050-0.077mm Regards, John |
Thanks John, that's exactly the type of information I was looking for.
So am I reading this right, on the inlet valve the standard size is 8.97mm and acceptable wear is up to .012mm? Wow, can't believe I guessed exactly right. |
Correct
Thanks again John, I appreciate it. Now got to do some research on head studs.
