-   -   Nick in nikasil (http://forums.pelicanparts.com/911-engine-rebuilding-forum/538911-nick-nikasil.html)
txhokie4life 04-24-2010 08:45 PM
Nick in lokasil
I've got an M96 block which had a bent rod in it.
While removing the rod/piston we nicked both side of the cylinder
about 1/2 way into the cylinder. Opposite sides, not quite at same elevation.
you can see it if you shine a light on both sides and feel it if you run
your finger nail across it (only the worst of the two shown below)
Is the cylinder compromised? Block toast now?
Or should we be able to rebuild?
Would we expect maybe the slightest compression loss?
thanks,
Mike
larger nick of the two
http://forums.pelicanparts.com/uploa...1272166957.jpg
Close Up
http://forums.pelicanparts.com/uploa...1272166973.jpg
Close up (high mag)-- looks worse in picture than in person.
http://forums.pelicanparts.com/uploa...1272166988.jpg
cnavarro 04-25-2010 02:58 PM
If it's below where the rings travel, you're probably safe.
The stock block isn't nikasil, it's lokasil - had it been nikasil you probably wouldn't have dinged it.
