-   -   Shroud missing? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/540011-shroud-missing.html)
4sd911 04-30-2010 06:14 PM
Shroud missing?
There is a gap between the oil cooler and the gray plastic shroud shown in this photo, is there a piece of shroud missing? Or is this normal?
http://forums.pelicanparts.com/uploa...1272676418.jpg
Flat6pac 04-30-2010 06:20 PM
What you have is all there is...
Bruce
OldTee 05-01-2010 07:09 AM
Engines that clean don't run well! SmileWavy
356RS 05-01-2010 08:52 AM
Looks like a rebuilt oil cooler and the top piece was welded in with a little more curve to it and now you have a gap. I'm just guessing from what the picture shows.
4sd911 05-01-2010 01:33 PM
The oil cooler was worked on by Pacific oil cooler service the receipt did state that some welding was done. I sent it to them for testing and cleaning. What could I use to fill that gap? Piece of aluminum? The gap is 7mm (1/4").
efhughes3 05-01-2010 06:45 PM
Don't sweat it-mine is the same.
Flat6pac 05-01-2010 06:58 PM
You can pull up on the aluminum to give you the fill you desire.
Bruce
Eagledriver 05-03-2010 04:06 PM
Mine has a strip of rubber glued to it to take up the space.
-Andy
