-   -   chain tensioner make up on 996 M96 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/540334-chain-tensioner-make-up-996-m96.html)
txhokie4life 05-02-2010 06:54 PM
While pre-oiling the chain tensioner one slipped out of the clamp.
the pin and spring ejected spetacularly. After a frantic witch hunt
I tracked down the spring and pin. Not sure if there were other parts.
Now when I reassemble it, the pin will not stay in place.
I'm not sure if I am missing another internal part, or if the pin needs to be
inserted and twisted just right.
I did note that the pin has one side that has flat notch 95% of the way.
thanks for any help.
Mike
C2951 05-05-2010 06:24 AM
Pic?
