Wierdness
We're at the Wendover NT and #4 is not firing at idle. It wakes up at around 3k rpms. Make a run and we come back to the staging lanes on all 6.....idle is up 2-3 hundred rpms and shut it off. Fire it back up for the next run and the hole is dead again. Back to the lanes & it's back on 6. Get back home and a compression test on the hole shows over 200 psi like the rest (+/- 10).
Idle jet is clean, spark seems maybe a bit weak (MSD set-up) but visable spark......
Ideas?
Oh..... 2nd of 13 in XP.
JPIII
Early Boxster
Old 05-18-2010, 08:46 PM
JP,
Sounds like a piece of schmutz in an idle passage. I'd remove the idle jet, drain the float bowl, and blow air back & forth several times from the main jet passage and idle jet to dislodge it.
In most cases you never see the offending crud.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-18-2010, 10:43 PM
